Ana içeriğe geç
EasySMX ESM-9110 Turbo Button Replacement
Neye ihtiyacın var
  1. EasySMX ESM-9110 Turbo Button Replacement, Handle Covers: adım 1, 2 resimden 1. EasySMX ESM-9110 Turbo Button Replacement, Handle Covers: adım 1, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Turbo Button Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Turbo Button Replacement: adım 3, 1 resimden 1.
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: adım 4, 3 resimden 1. EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: adım 4, 3 resimden 2. EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: adım 4, 3 resimden 3.
    • Use a Philips #000 screwdriver to remove the six 20 mm screws from the controller's faceplate.
  5. EasySMX ESM-9110 Turbo Button Replacement: adım 5, 3 resimden 1. EasySMX ESM-9110 Turbo Button Replacement: adım 5, 3 resimden 2. EasySMX ESM-9110 Turbo Button Replacement: adım 5, 3 resimden 3.
    • Using a soldering iron, solder the turbo button.
Sonuç
Melanie Rodriguez
406 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Konn Spring 2024 UMass Dartmouth, Team 2-4, Konn Spring 2024 üyesi
UMASSD-KONN-S24S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 274
