Ana içeriğe geç
EasySMX ESM-9110 Vibration Motor Replacement
Neye ihtiyacın var
  1. EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: adım 1, 2 resimden 1. EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: adım 1, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Vibration Motor Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Vibration Motor Replacement: adım 3, 1 resimden 1.
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: adım 4, 3 resimden 1. EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: adım 4, 3 resimden 2. EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: adım 4, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • The screw extender should only be used to unscrew two of the six screws. Do not use it for all six.
  5. EasySMX ESM-9110 Vibration Motor Replacement: adım 5, 2 resimden 1. EasySMX ESM-9110 Vibration Motor Replacement: adım 5, 2 resimden 2.
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle, the controller's backplate is still attached. Do not move the controller too roughly.
  6. EasySMX ESM-9110 Vibration Motor Replacement: adım 6, 2 resimden 1. EasySMX ESM-9110 Vibration Motor Replacement: adım 6, 2 resimden 2.
    • Locate the parts of the vibration motor that are connected to the motherboard
    • Solder these parts of the vibration motor to remove them.
    • There should be two connectors present in your controller, one for each vibration motor.
Sonuç
Melanie Rodriguez
406 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Konn Spring 2024 UMass Dartmouth, Team 2-4, Konn Spring 2024 üyesi
UMASSD-KONN-S24S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 280
