Ana içeriğe geç
EasySMX X15 Bottom Casing Replacement
Neye ihtiyacın var
  1. EasySMX X15 Bottom Casing Replacement, Bottom Casing: adım 1, 2 resimden 1. EasySMX X15 Bottom Casing Replacement, Bottom Casing: adım 1, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
Sonuç
ShawnDetiveaux
637 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 42
