Ana içeriğe geç
EasySMX X15 D-Pad Replacement
Neye ihtiyacın var
  1. EasySMX X15 D-Pad Replacement, Bottom Casing: adım 1, 2 resimden 1. EasySMX X15 D-Pad Replacement, Bottom Casing: adım 1, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    FixBot'a Sor
    Yorum Ekle
  2. EasySMX X15 D-Pad Replacement, Main Board: adım 2, 1 resimden 1.
    • Disconnect the vibration motor cables from the connectors on the circuit board.
    • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
    FixBot'a Sor
    Yorum Ekle
  3. EasySMX X15 D-Pad Replacement: adım 3, 1 resimden 1.
    • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
    FixBot'a Sor
    Yorum Ekle
  4. EasySMX X15 D-Pad Replacement, D-Pad: adım 4, 2 resimden 1. EasySMX X15 D-Pad Replacement, D-Pad: adım 4, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the four 4 mm screws securing the D-pad to the controller casing.
    • Lift the back of the D-pad, along with the membrane, to remove them from the controller.
    • Lift up the case, allowing the D-pad to detach from the top of the casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Cameron Gattis
185 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 632
