Ana içeriğe geç
Eatsmart ESBS-01 Battery Replacement
  1. Eatsmart ESBS-01 Battery Replacement, Battery: adım 1, 2 resimden 1. Eatsmart ESBS-01 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • The LO message on the screen indicates that your digital weight scale is running on low battery so you need to get the replacement battery.
    • This area is where the batteries located, top right corner of the scale.
  2. Eatsmart ESBS-01 Battery Replacement: adım 2, 2 resimden 1. Eatsmart ESBS-01 Battery Replacement: adım 2, 2 resimden 2.
    • To open the battery compartment, use your finger to gentling push the tip to open the battery compartment.
  3. Eatsmart ESBS-01 Battery Replacement: adım 3, 2 resimden 1. Eatsmart ESBS-01 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the old batteries from the device by pushing the battery toward the wire side and gentling taking it out.
  4. Eatsmart ESBS-01 Battery Replacement: adım 4, 2 resimden 1. Eatsmart ESBS-01 Battery Replacement: adım 4, 2 resimden 2.
    • Insert the new batteries in the device.
    • Be aware to place the batteries in the right charge. The positive (+) and negative (-) signs are labeled inside the battery compartment. Place the flat side of the battery to the negative side and the little lip side of the battery to the positive side on the device.
  5. Eatsmart ESBS-01 Battery Replacement: adım 5, 3 resimden 1. Eatsmart ESBS-01 Battery Replacement: adım 5, 3 resimden 2. Eatsmart ESBS-01 Battery Replacement: adım 5, 3 resimden 3.
    • Put the cover of the compartment back. You successfully replaced the batteries.
    • You should now see the weight displaying on the screen after the replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elle Luo
137 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S4-G1, Cole Spring 2017 UC Davis, Team S4-G1, Cole Spring 2017 üyesi
UCD-COLE-S17S4G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 49
Her zaman: 1,954
