Giriş
Use this guide to replace the carburetor in your Echo Chain Saw CS-590 (2019).
Although it's not necessary to remove the guide bar, it's highly recommended you do so to minimize any damage to the chain and to yourself.
Note: Check that the serial number on your replacement part matches the one listed in the "Parts" section of this guide.
Neye ihtiyacın var
Make sure you have the ignition switch turned off before starting your repair.
Use your fingers to pull up and disconnect the spark plug boot.
Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
Four 24 mm-long screws
One 25 mm-long screw
Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
Push the guide bar towards the back of the device to create slack in the saw chain.
Pull the guide bar away from the device to separate the saw chain from the clutch drum.
Remove the guide bar.
Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
Pull the front hand guard toward the rear of the device to remove it.
Use a T25 Torx screwdriver to remove the three 20 mm screws securing the engine cover.
Use a T25 Torx screwdriver to remove the two 54 mm screws securing the carburetor cover.
Pull the carburetor cover straight off its housing to remove it.
Use your fingers to pull the right fuel pipe out of the carburetor.
Repeat the same procedure for the left fuel pipe.
Lift the carburetor out of its housing.
Twist the carburetor counter-clockwise to disconnect the throttle rod's metal clip.
Remove the carburetor.
5 farklı kişi bu kılavuzu tamamladı.
