Giriş
Use this guide to replace the ignition assembly in your Echo Chain Saw CS-590 (2019). The ignition assembly includes the ignition coil, flywheel, and the woodruff key.
Although it's not necessary to remove the guide bar, it's highly recommended you do so to minimize any damage to the chain and to yourself.
Neye ihtiyacın var
Make sure you have the ignition switch turned off before starting your repair.
Use your fingers to pull up and disconnect the spark plug boot.
Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
Four 24 mm-long screws
One 25 mm-long screw
Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
Push the guide bar towards the back of the device to create slack in the saw chain.
Pull the guide bar away from the device to separate the saw chain from the clutch drum.
Remove the guide bar.
Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
Pull the front hand guard toward the rear of the device to remove it.
Use a T25 Torx screwdriver to remove the three 20 mm screws securing the engine cover.
Use a T25 Torx screwdriver to remove the four 24 mm screws securing the starter case.
Use your fingers to reroute the spark plug cable from its slot in the fan cover.
Use your fingers to reroute the ignition coil cable from its slot in the fan cover.
Use pliers, or your fingers, to disconnect the ignition coil cable's spade connector.
Use a T25 Torx screwdriver to remove the two 20 mm screws securing the ignition coil.
Wedge a flathead screwdriver between the chassis and the flywheel's spokes to prevent the flywheel from spinning.
Use a 13 mm wrench to loosen and remove the flange nut located in the middle of the flywheel.
Use a T25 Torx screwdriver to remove the two 16 mm screws securing the starter pawls.
Remove the starter pawls.
16 mm screw
Washer
Starter Pawl
Spacer
Torsion Spring
Use a flywheel puller to disconnect the flywheel from the woodruff key.
Insert a flathead screwdriver into the gap at the top of the woodruff key.
Pry with the screwdriver to separate the key from the crankshaft.
Bir başkası bu kılavuzu tamamladı.
