Ana içeriğe geç
Echo Dot 3 Mic/LEDs/Button Replacement
Neye ihtiyacın var
  1. Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: adım 1, 2 resimden 1. Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: adım 1, 2 resimden 2.
    • Turn your Dot around, so that the Barcode is facing up, and the buttons down.
  2. Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": adım 2, 2 resimden 1. Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • Using a Spudger remove the Lid.
    • There's Adhesive under the lid, so the best way to get it off, is to go all the way around with the Spudger
  3. Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: adım 3, 3 resimden 1. Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: adım 3, 3 resimden 2. Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: adım 3, 3 resimden 3.
    TR6 Torx Security Screwdriver
    $5.99
    • Unscrew the 4 T6 Torx screws using the Right Screwdriver
    • After unscrewing, you can slowly lift the shell, and you'll be greeted by the insides of the Dot!
  4. Echo Dot 3 Mic/LEDs/Button Replacement, Insides: adım 4, 3 resimden 1. Echo Dot 3 Mic/LEDs/Button Replacement, Insides: adım 4, 3 resimden 2. Echo Dot 3 Mic/LEDs/Button Replacement, Insides: adım 4, 3 resimden 3.
    • Unscrew the 3 T6 Torx screws,
    • and lift the flex cable connector.
    • After that, very carefully remove the PCB/Power supply (no idea).
  5. Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: adım 5, 2 resimden 1. Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: adım 5, 2 resimden 2.
    • Remove the 4 T6 Torx screws (2 different lengths!)
    • Slowly Remove the Middle part
    • Be very careful while removing the middle part, so that you don't damage the cable!
  6. Echo Dot 3 Mic/LEDs/Button Replacement, Top part: adım 6, 3 resimden 1. Echo Dot 3 Mic/LEDs/Button Replacement, Top part: adım 6, 3 resimden 2. Echo Dot 3 Mic/LEDs/Button Replacement, Top part: adım 6, 3 resimden 3.
    • Remove the 4 T6 Torx screws,
    • and lift the plastic to remove it.
  7. Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: adım 7, 3 resimden 1. Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: adım 7, 3 resimden 2. Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: adım 7, 3 resimden 3.
    • Simply flip the device to separate the:
    • Motherboard and
    • Buttons from each other.
Sonuç
Congrats! To put together your Echo Dot, simply follow the instructions backward! Have a nice day!
2 farklı kişi bu kılavuzu tamamladı.
ashlynn
190 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 823
