Giriş
Use this guide to replace the small flexible tube that sits below the handle on an Echo Power Pruner 254 cc PPT2620 2019.
Neye ihtiyacın var
Use a T25 Torx screwdriver to loosen (but not remove) the two screws clamping the main pipe assembly to the control handle.
Use a T25 Torx screwdriver to remove the seven screws holding the control handle together.
Use a T25 Torx screwdriver to loosen (but don't remove) the screw clamping the strap hook to the handle pipe.
Remove the two T25 screws securing the handle to the handle pipe.
Slide the flexible tube off of the handle pipe and remove it.
2 farklı kişi bu kılavuzu tamamladı.
