Ana içeriğe geç
Eclipse 180BL Battery Replacement
Neye ihtiyacın var
  1. Eclipse 180BL Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
  2. Eclipse 180BL Battery Replacement: adım 2, 2 resimden 1. Eclipse 180BL Battery Replacement: adım 2, 2 resimden 2.
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
  3. Eclipse 180BL Battery Replacement: adım 3, 3 resimden 1. Eclipse 180BL Battery Replacement: adım 3, 3 resimden 2. Eclipse 180BL Battery Replacement: adım 3, 3 resimden 3.
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
  4. Eclipse 180BL Battery Replacement: adım 4, 1 resimden 1.
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Thomas Schwarz
499 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,412
