Ana içeriğe geç
Eclipse 180BL LCD Screen Cover Replacement
Neye ihtiyacın var
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: adım 1, 3 resimden 1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: adım 1, 3 resimden 2. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: adım 1, 3 resimden 3.
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: adım 2, 3 resimden 1. Eclipse 180BL LCD Screen Cover Replacement: adım 2, 3 resimden 2. Eclipse 180BL LCD Screen Cover Replacement: adım 2, 3 resimden 3.
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
Sonuç
Thomas Schwarz
499 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 543
