Ana içeriğe geç
Eclipse 180BL Touch Pad Replacement
Neye ihtiyacın var
  1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: adım 1, 1 resimden 1.
    • Remove the two screws at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
    • The two screws are 1/8 inch in length.
    • Remove the cover to reveal the internal component.
    FixBot'a Sor
    Yorum Ekle
  2. Eclipse 180BL Touch Pad  Replacement: adım 2, 3 resimden 1. Eclipse 180BL Touch Pad  Replacement: adım 2, 3 resimden 2. Eclipse 180BL Touch Pad  Replacement: adım 2, 3 resimden 3.
    • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
    • This will release the tension on the multiple parts. One of which will be the touch pad.
    • The touch pad can now be easily replaced.
    • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thomas Schwarz
499 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 1,062
