Ana içeriğe geç
Eclipse 180G2 Outer Case Replacement
Neye ihtiyacın var
  1. Eclipse 180G2 Outer Case Replacement, Outer Case: adım 1, 2 resimden 1. Eclipse 180G2 Outer Case Replacement, Outer Case: adım 1, 2 resimden 2.
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: adım 2, 3 resimden 1. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: adım 2, 3 resimden 2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: adım 2, 3 resimden 3.
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jesse Minor
662 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Tanski Winter 2015 USF Tampa, Team 1-4, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G4
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
What if there is no charge port or USB port there no longer?
May 303 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,328
