Giriş
Removal of the internal circuit is crucial step in replacing any component. This guide is the first step in replacing any part on the device.
Neye ihtiyacın var
Remove the two screws on the bottom of the device with a Phillips head screwdriver.
Use a spudger to remove the plastic plate from the bottom of the player.
Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
Use the spudger to push the USB port on the bottom of the device inward.
The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
3 farklı kişi bu kılavuzu tamamladı.
I can't budge the inner parts from its casing
tailoredvisions - Yanıt
