Giriş
This guide is required when there is no audio coming from the device as a result of a broken speaker. To replace the speaker, it is required to solder the replacement speaker to the motherboard. This is a safety hazard and specific soldering equipment is needed. When soldering, protective equipment needs to be warn for caution.
Neye ihtiyacın var
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws
Neredeyse bitti!
Sonuç
