Giriş
This guide is used when the toggle button is no longer functioning properly. If you are experiencing a loose or broken toggle button it must be replaced to keep the device operating normally.
Neye ihtiyacın var
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Neredeyse bitti!
Sonuç
