Ana içeriğe geç
Eco X Gear Battery Replacement
Neye ihtiyacın var
  1. Eco X Gear Battery Replacement, Frame: adım 1, 1 resimden 1.
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: adım 2, 1 resimden 1.
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: adım 3, 1 resimden 1.
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: adım 4, 1 resimden 1.
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: adım 6, 2 resimden 1. Eco X Gear Battery Replacement: adım 6, 2 resimden 2.
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: adım 7, 1 resimden 1.
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: adım 8, 1 resimden 1.
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: adım 9, 1 resimden 1.
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Lipsett
625 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G3, Martin Spring 2017 UMass Dartmouth, Team S9-G3, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G3
2 Üyeler
3 Yorum
Where to get the new battery?
James Chen - Yanıt
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 671
