Ana içeriğe geç
Eco X Gear LED Display Replacement
Neye ihtiyacın var
  1. Eco X Gear LED Display Replacement, Frame: adım 1, 1 resimden 1.
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear LED Display Replacement: adım 2, 1 resimden 1.
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear LED Display Replacement: adım 3, 1 resimden 1.
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear LED Display Replacement: adım 4, 1 resimden 1.
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear LED Display Replacement, LED Display: adım 5, 1 resimden 1.
    • Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
  6. Eco X Gear LED Display Replacement: adım 6, 1 resimden 1.
    • Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
Sonuç
James Lipsett
625 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G3, Martin Spring 2017 UMass Dartmouth, Team S9-G3, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G3
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 137
