Ana içeriğe geç
Eco X Gear Voice Coil Replacement
Neye ihtiyacın var
  1. Eco X Gear Voice Coil Replacement, Frame: adım 1, 1 resimden 1.
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Voice Coil Replacement: adım 2, 1 resimden 1.
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Voice Coil Replacement: adım 3, 1 resimden 1.
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Voice Coil Replacement: adım 4, 1 resimden 1.
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Voice Coil Replacement, Voice Coil: adım 5, 1 resimden 1.
    • Disconnect the wiring to improve accessibility to the cones.
  6. Eco X Gear Voice Coil Replacement: adım 6, 2 resimden 1. Eco X Gear Voice Coil Replacement: adım 6, 2 resimden 2.
    • Remove the four screws that hold down the speaker and pry up the speaker from the frame.
  7. Eco X Gear Voice Coil Replacement: adım 7, 1 resimden 1.
    • Once the voice coil is removed, solder it back onto the bracket or replace the voice coil entirely.
Sonuç
James Lipsett
625 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G3, Martin Spring 2017 UMass Dartmouth, Team S9-G3, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G3
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 179
