Giriş
This guide is for replacing the battery in the SmartSensor. The battery is not rechargeable so it will need to be replaced in case of malfunction. You can use your fingernail or some other small flat tool to pry open the back of the SmartSensor.
No past experience in the electrical field is needed.
Neye ihtiyacın var
Identify which part is the battery sensor. The battery sensor looks like this image and is a small, cube-like shape.
Bir başkası bu kılavuzu tamamladı.
