Ana içeriğe geç
Ecovacs DEEBOT D35 Vacuum Motor Replacement
Neye ihtiyacın var
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: adım 1, 1 resimden 1.
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: adım 2, 1 resimden 1.
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: adım 3, 1 resimden 1.
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: adım 4, 1 resimden 1.
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: adım 5, 1 resimden 1.
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: adım 6, 1 resimden 1.
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: adım 7, 1 resimden 1.
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: adım 8, 1 resimden 1.
    • Remove the vacuum motor body
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brian
475 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-2, Eyestone Spring 2017 USF Tampa, Team 12-2, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G2
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
thanks a lots for the valuable info
sk law - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 9,092
