Ana içeriğe geç
Ecovacs Deebot 900 Battery Replacement
Neye ihtiyacın var
  1. Ecovacs Deebot 900 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Battery Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Battery Replacement: adım 4, 1 resimden 1.
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Battery Replacement: adım 5, 1 resimden 1.
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Great guide except no information on where to actually FIND a battery for this thing
Chris Staley - Yanıt
Where can replacement battery packs be acquired from?
Larry Smith - Yanıt
You can find the battery at Taobao online shopping
Jimmy - Yanıt
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
Kevin Dunn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 93
Son 30 gün: 443
Her zaman: 22,086
