Ana içeriğe geç
Ecovacs Deebot 900 Vacuum Motor Replacement
Neye ihtiyacın var
  1. Ecovacs Deebot 900 Vacuum Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 3, 1 resimden 1.
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 4, 1 resimden 1.
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 5, 1 resimden 1.
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Vacuum Motor Replacement, Front Bumper: adım 6, 2 resimden 1. Ecovacs Deebot 900 Vacuum Motor Replacement, Front Bumper: adım 6, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 7, 1 resimden 1.
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 8, 2 resimden 1. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 8, 2 resimden 2.
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 9, 2 resimden 1. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 9, 2 resimden 2.
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Vacuum Motor Replacement, Bottom Case: adım 10, 2 resimden 1. Ecovacs Deebot 900 Vacuum Motor Replacement, Bottom Case: adım 10, 2 resimden 2.
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 11, 2 resimden 1. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 11, 2 resimden 2.
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  12. Ecovacs Deebot 900 Vacuum Motor Replacement, Vacuum Motor: adım 12, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the three screws around the laser unit.
  13. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 13, 2 resimden 1. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 13, 2 resimden 2.
    • Carefully lift the laser unit off of the motor assembly​.
  14. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 14, 1 resimden 1.
    • Remove the single screw holding the motor assembly in place using the Phillips #00 screwdriver.
  15. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 15, 2 resimden 1. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 15, 2 resimden 2.
    • Disconnect the ribbon cable holding the assembly in place.
    • Be careful not to damage the cable.
  16. Ecovacs Deebot 900 Vacuum Motor Replacement: adım 16, 1 resimden 1.
    • Lift and remove the motor assembly out of the Deebot.​
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Where can you find a replacement vacuum motor for the zoom 930?
Aaron Commons - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 102
Her zaman: 10,964
