Ana içeriğe geç
Ecovacs Deebot 900 Wheel Replacement
Neye ihtiyacın var
  1. Ecovacs Deebot 900 Wheel Replacement, Battery: adım 1, 1 resimden 1.
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Wheel Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Wheel Replacement: adım 3, 1 resimden 1.
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Wheel Replacement: adım 4, 1 resimden 1.
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Wheel Replacement: adım 5, 1 resimden 1.
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Wheel Replacement, Front Bumper: adım 6, 2 resimden 1. Ecovacs Deebot 900 Wheel Replacement, Front Bumper: adım 6, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Wheel Replacement: adım 7, 1 resimden 1.
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Wheel Replacement: adım 8, 2 resimden 1. Ecovacs Deebot 900 Wheel Replacement: adım 8, 2 resimden 2.
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Wheel Replacement: adım 9, 2 resimden 1. Ecovacs Deebot 900 Wheel Replacement: adım 9, 2 resimden 2.
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Wheel Replacement, Bottom Case: adım 10, 2 resimden 1. Ecovacs Deebot 900 Wheel Replacement, Bottom Case: adım 10, 2 resimden 2.
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Wheel Replacement: adım 11, 2 resimden 1. Ecovacs Deebot 900 Wheel Replacement: adım 11, 2 resimden 2.
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  12. Ecovacs Deebot 900 Wheel Replacement, Motherboard: adım 12, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  13. Ecovacs Deebot 900 Wheel Replacement: adım 13, 1 resimden 1.
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  14. Ecovacs Deebot 900 Wheel Replacement: adım 14, 1 resimden 1.
    • Remove the last three ribbon cables on the underside of the motherboard.​
  15. Ecovacs Deebot 900 Wheel Replacement: adım 15, 1 resimden 1.
    • Lift the motherboard out of the Deebot and remove it from the device.
  16. Ecovacs Deebot 900 Wheel Replacement, Wheel: adım 16, 1 resimden 1.
    • Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
  17. Ecovacs Deebot 900 Wheel Replacement: adım 17, 2 resimden 1. Ecovacs Deebot 900 Wheel Replacement: adım 17, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
  18. Ecovacs Deebot 900 Wheel Replacement: adım 18, 1 resimden 1.
    • Remove the wheel cover.
  19. Ecovacs Deebot 900 Wheel Replacement: adım 19, 3 resimden 1. Ecovacs Deebot 900 Wheel Replacement: adım 19, 3 resimden 2. Ecovacs Deebot 900 Wheel Replacement: adım 19, 3 resimden 3.
    • Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
  20. Ecovacs Deebot 900 Wheel Replacement: adım 20, 2 resimden 1. Ecovacs Deebot 900 Wheel Replacement: adım 20, 2 resimden 2.
    • Lift up and remove the wheel assembly and the attached sensor (black cable).
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Thanks, it helps a lot
Agoston David - Yanıt
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
OldManInChicago - Yanıt
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Plewu Gracz - Yanıt
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
wong CS - Yanıt
The rubber tires on my Deebot have worn through. Does anybody have a source for rubber tire replacement? The company wants to sell me two entire wheel assemblies. I find that unreasonable.
akobelan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 185
Son 30 gün: 727
Her zaman: 42,818
