Giriş
The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the wheels are jammed, the Deebot will not be able to clean around your house. Use this guide to replace the wheel of the Ecovacs Deebot 900.
Neye ihtiyacın var
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
I have two issues with these instructions.
Title is Ecovacs Deebot 900 Battery Replacement. The battery was never replaced the device was reassembled.
For battery replacement you need a battery it would be nice to have the replacement battery part number as well.
I’d like some more info on part numbers, too. I have a Deebot 901 with a battery that, already after 2 years, has deteriorated significantly. Deebot 901 is also called “DE5G.10” in Europe, and it’s existing Battery back has model number ZJ1517-HFR, on which I can find almost no info, let a lone a compatible part somewhere in The Netherlands.
eymert -
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.
Carefully remove the ribbon cables connected to the top of motherboard.
It could be give you put letters on the cable connects A to Z on the picture so when putting them back you could check on the picture if you forgot any.
Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
6 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Thanks, it helps a lot
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
To every one that got broken motor gears. You can buy them on ali or ebay. Fix is easy and done even as unprofessional as me. You can also print them if you have god material. I've found 3d printing model for this if someone need it- mail/ pm me.
