Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Carefully lift up the bumper untill it pops out of place.
Disconnect the two cables connecting the bumper to the body of the Deebot.
Remove the front bumper from the device.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Insert a Jimmy into the seam and work all the way around the robot.
Disconnect the two cables and remove the bottom case from the device.
Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.
Carefully remove the ribbon cables connected to the top of motherboard.
Remove the last three ribbon cables on the underside of the motherboard.
Lift the motherboard out of the Deebot and remove it from the device.
Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
Lift up and remove the wheel assembly and the attached sensor (black cable).
6 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Thanks, it helps a lot
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
