Ana içeriğe geç
Edco KL14 Engine Replacement
Neye ihtiyacın var
  1. Edco KL14 Engine Replacement, Disengage the Spark Plug: adım 1, 2 resimden 1. Edco KL14 Engine Replacement, Disengage the Spark Plug: adım 1, 2 resimden 2.
    • Before you begin, ensure that the machine is powered down and cool to the touch.
    • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
    • Grab the plastic spark plug cap at the end of the spark plug wire.
    • Firmly pull to disconnect the spark plug cap from the spark plug.
  2. Edco KL14 Engine Replacement, Place Wheel Chocks: adım 2, 3 resimden 1. Edco KL14 Engine Replacement, Place Wheel Chocks: adım 2, 3 resimden 2. Edco KL14 Engine Replacement, Place Wheel Chocks: adım 2, 3 resimden 3.
    • To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
  3. Edco KL14 Engine Replacement, Remove the Arbor Guard: adım 3, 2 resimden 1. Edco KL14 Engine Replacement, Remove the Arbor Guard: adım 3, 2 resimden 2.
    • Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
    • Remove the arbor guard.
  4. Edco KL14 Engine Replacement, Remove the Belt Guard: adım 4, 3 resimden 1. Edco KL14 Engine Replacement, Remove the Belt Guard: adım 4, 3 resimden 2. Edco KL14 Engine Replacement, Remove the Belt Guard: adım 4, 3 resimden 3.
    • Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
    • Remove the belt guard.
  5. Edco KL14 Engine Replacement, Loosen the Engine Mount Bolts: adım 5, 2 resimden 1. Edco KL14 Engine Replacement, Loosen the Engine Mount Bolts: adım 5, 2 resimden 2.
    • Use a 9/16-inch wrench to loosen the lock nut on the engine's tap bolt.
  6. Edco KL14 Engine Replacement: adım 6, 2 resimden 1. Edco KL14 Engine Replacement: adım 6, 2 resimden 2.
    • Use a 9/16-inch wrench to loosen the engine's tap bolt until the tip of the bolt is about an inch away from the engine.
  7. Edco KL14 Engine Replacement: adım 7, 2 resimden 1. Edco KL14 Engine Replacement: adım 7, 2 resimden 2.
    • Use a 9/16-inch wrench to loosen the five engine mounting nuts on the front and back of the engine, but do not remove them.
  8. Edco KL14 Engine Replacement, Remove the Drain Hose Clamp Screw: adım 8, 1 resimden 1.
    • Use a flathead screwdriver or a 3/8-inch wrench to remove the screw securing the drain hose to the concrete saw.
  9. Edco KL14 Engine Replacement, Relieve Tension on the Belts: adım 9, 2 resimden 1. Edco KL14 Engine Replacement, Relieve Tension on the Belts: adım 9, 2 resimden 2.
    • Slide the engine forward on the frame to relieve tension on the belts.
  10. Edco KL14 Engine Replacement, Remove the Belts: adım 10, 3 resimden 1. Edco KL14 Engine Replacement, Remove the Belts: adım 10, 3 resimden 2. Edco KL14 Engine Replacement, Remove the Belts: adım 10, 3 resimden 3.
    • Remove the outer belt from the engine and arbor pulleys.
    • It may help to use one hand to remove the belts from the engine pulley and the other hand to remove the belts from the arbor pulley.
    • Repeat the process for the inner belt.
  11. Edco KL14 Engine Replacement, Remove the Air Filter Cover: adım 11, 3 resimden 1. Edco KL14 Engine Replacement, Remove the Air Filter Cover: adım 11, 3 resimden 2. Edco KL14 Engine Replacement, Remove the Air Filter Cover: adım 11, 3 resimden 3.
    • Use your fingers to unscrew and remove the wing nut securing the air filter cover.
  12. Edco KL14 Engine Replacement: adım 12, 2 resimden 1. Edco KL14 Engine Replacement: adım 12, 2 resimden 2.
    • Lift the air filter cover straight up to remove it.
  13. Edco KL14 Engine Replacement, Remove the Air Filter: adım 13, 3 resimden 1. Edco KL14 Engine Replacement, Remove the Air Filter: adım 13, 3 resimden 2. Edco KL14 Engine Replacement, Remove the Air Filter: adım 13, 3 resimden 3.
    • Use your fingers to unscrew and remove the wing nut securing the air filter.
  14. Edco KL14 Engine Replacement: adım 14, 2 resimden 1. Edco KL14 Engine Replacement: adım 14, 2 resimden 2.
    • Grab the black plastic air filter platform and lift it straight up with the air filter to remove both components.
  15. Edco KL14 Engine Replacement, Remove the Throttle Cable: adım 15, 3 resimden 1. Edco KL14 Engine Replacement, Remove the Throttle Cable: adım 15, 3 resimden 2. Edco KL14 Engine Replacement, Remove the Throttle Cable: adım 15, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the screw securing the throttle cable to the engine.
    • Grab the throttle cable clamp with your fingers and rotate it out of the way of the throttle cable.
  16. Edco KL14 Engine Replacement: adım 16, 3 resimden 1. Edco KL14 Engine Replacement: adım 16, 3 resimden 2. Edco KL14 Engine Replacement: adım 16, 3 resimden 3.
    • Lift the throttle cable up and pull it the end of the cable out of the hole it hooks into.
    • Make sure to reinstall the throttle cable onto the new engine. You'll need to remove the air filter on the new engine first.
  17. Edco KL14 Engine Replacement, Disconnect the Switch Wires: adım 17, 3 resimden 1. Edco KL14 Engine Replacement, Disconnect the Switch Wires: adım 17, 3 resimden 2. Edco KL14 Engine Replacement, Disconnect the Switch Wires: adım 17, 3 resimden 3.
    • Unclip the blue wire connector on the front of the engine.
    • Remove the wire connector from the engine's switch wire.
    • Leave the handle switch's black wire connected to the wire connector.
    • Make sure to reattach the wire connector to the new engine's switch wire.
  18. Edco KL14 Engine Replacement, Remove the Drive Pulley: adım 18, 1 resimden 1.
    • Use a 1/8-inch hex key to loosen the two set screws on the engine's drive pulley.
    • Completely removing the set screws is not required to remove the drive pulley.
  19. Edco KL14 Engine Replacement: adım 19, 3 resimden 1. Edco KL14 Engine Replacement: adım 19, 3 resimden 2. Edco KL14 Engine Replacement: adım 19, 3 resimden 3.
    • Use a gear puller and a wrench to remove the pulley from the engine's driveshaft.
    • Make sure to reinstall this pulley onto the new engine's driveshaft.
  20. Edco KL14 Engine Replacement: adım 20, 1 resimden 1.
    • Remove the drive pulley key from the driveshaft.
    • If the new engine did not come with a new drive pulley key, you can transfer this key from the old engine to the new one.
  21. Edco KL14 Engine Replacement, Remove the Engine Mount Nuts and Bolts: adım 21, 3 resimden 1. Edco KL14 Engine Replacement, Remove the Engine Mount Nuts and Bolts: adım 21, 3 resimden 2. Edco KL14 Engine Replacement, Remove the Engine Mount Nuts and Bolts: adım 21, 3 resimden 3.
    • Use a 9/16-inch wrench to remove the three engine mount nuts and the ground wire at the front of the engine.
    • Place a hand underneath the frame to catch the carriage bolts as you remove the nuts.
    • The engine mount bolt with two nuts and a ground wire (shown on the left side of the first photo in this step) is longer than the other bolts securing the engine. During reassembly, make sure to reuse the longer bolt on the correct side and reinstall the ground wire between the two nuts.
  22. Edco KL14 Engine Replacement: adım 22, 1 resimden 1.
    • Use a 9/16-inch wrench to remove the two engine mount nuts on the back of the engine.
  23. Edco KL14 Engine Replacement, Remove the Engine: adım 23, 2 resimden 1. Edco KL14 Engine Replacement, Remove the Engine: adım 23, 2 resimden 2.
    • Use both hands and carefully lift the engine straight up off the concrete saw to remove it.
    • Get help from another person, if need be.
  24. Edco KL14 Engine Replacement, Remove the Drain Hose from the Engine: adım 24, 3 resimden 1. Edco KL14 Engine Replacement, Remove the Drain Hose from the Engine: adım 24, 3 resimden 2. Edco KL14 Engine Replacement, Remove the Drain Hose from the Engine: adım 24, 3 resimden 3.
    • Place the engine on your work surface and prop up the rear by placing a wooden block underneath it.
    • Use a 5/8-inch wrench to unscrew and remove the drain bolt from the engine.
    • Make sure to install this drain hose onto the new engine.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Craig Lloyd
33.877 İtibar
82 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 27
Her zaman: 935
