Ana içeriğe geç
Edwin the Duck Motherboard Replacement
Neye ihtiyacın var
  1. Edwin the Duck Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Edwin the Duck Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Unscrew the four 9mm screws with a T8 screwdriver bit
    • Remove the back plate off
  2. Edwin the Duck Motherboard Replacement: adım 2, 2 resimden 1. Edwin the Duck Motherboard Replacement: adım 2, 2 resimden 2.
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in losing the waterproof cover.
  3. Edwin the Duck Motherboard Replacement: adım 3, 1 resimden 1.
    • Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Motherboard Replacement: adım 4, 2 resimden 1. Edwin the Duck Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Motherboard Replacement: adım 5, 2 resimden 1. Edwin the Duck Motherboard Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab, up slowly
  6. Edwin the Duck Motherboard Replacement: adım 6, 1 resimden 1.
    • Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
  7. Edwin the Duck Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the top connector as you see in the picture.
    • Replace the new motherboard and you are finished.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caleb Kim
143 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 449
