Ana içeriğe geç
Edwin the Duck Rubber Gasket Seal Replacement
Neye ihtiyacın var
  1. Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: adım 1, 2 resimden 1. Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: adım 1, 2 resimden 2.
    • Unscrew the four 9mm screws with aT8 bit
    • Take the back plate off
  2. Edwin the Duck Rubber Gasket Seal Replacement: adım 2, 2 resimden 1. Edwin the Duck Rubber Gasket Seal Replacement: adım 2, 2 resimden 2.
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin otherwise you will lose the waterproof cover.
  3. Edwin the Duck Rubber Gasket Seal Replacement: adım 3, 1 resimden 1.
    • Using the J1 bit, unscrew all six 9 mm screws around the border.
  4. Edwin the Duck Rubber Gasket Seal Replacement: adım 4, 2 resimden 1. Edwin the Duck Rubber Gasket Seal Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Rubber Gasket Seal Replacement: adım 5, 2 resimden 1. Edwin the Duck Rubber Gasket Seal Replacement: adım 5, 2 resimden 2.
    • Remove the rubber gasket
  6. Edwin the Duck Rubber Gasket Seal Replacement: adım 6, 1 resimden 1.
    • Insert your new rubber gasket in and use the plastic opening tool to push the rubber gasket into it's slot
Sonuç
Nadia Dobrogorskaya
131 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 387
