Ana içeriğe geç
Eee Pad Transformer Prime TF201 -- Opening Your Device
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Eee Pad Transformer Prime TF201 -- Opening Your Device, Opening Your Device: adım 1, 1 resimden 1.
    • Power down your device.
    • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
  2. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 2, 3 resimden 1. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 2, 3 resimden 2. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the seam near the corner of the device.
    • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
    • It is normal to hear snaps as the spring clips holding the screen in place are released.
    • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
  3. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 3, 3 resimden 1. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 3, 3 resimden 2. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 3, 3 resimden 3.
    • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
    • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
    • Safely place the device back on the table by laying the screen face down.
    • There will be some slight overlapping of the back of the case over the screen.
  4. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 4, 2 resimden 1. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 4, 2 resimden 2.
    • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
    • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
  5. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 5, 1 resimden 1.
    • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
    • Repeat the previous process to remove the other ribbon cable.
  6. Eee Pad Transformer Prime TF201 -- Opening Your Device: adım 6, 1 resimden 1.
    • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
    • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
    • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Morland
346 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-1, Livingston Fall 2016 Cal Poly, Team 10-1, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G1
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 103
