Ana içeriğe geç
Eee Pad Transformer Prime TF201 Screen Replacement
Neye ihtiyacın var
    1. Eee Pad Transformer Prime TF201 Screen Replacement, Opening Your Device: adım 1, 1 resimden 1.
      • Power down your device.
      • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
      FixBot'a Sor
      Yorum Ekle
    2. Eee Pad Transformer Prime TF201 Screen Replacement: adım 2, 3 resimden 1. Eee Pad Transformer Prime TF201 Screen Replacement: adım 2, 3 resimden 2. Eee Pad Transformer Prime TF201 Screen Replacement: adım 2, 3 resimden 3.
      • Insert the plastic opening tool into the seam near the corner of the device.
      • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
      • It is normal to hear snaps as the spring clips holding the screen in place are released.
      • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
      FixBot'a Sor
      Yorum Ekle
    3. Eee Pad Transformer Prime TF201 Screen Replacement: adım 3, 3 resimden 1. Eee Pad Transformer Prime TF201 Screen Replacement: adım 3, 3 resimden 2. Eee Pad Transformer Prime TF201 Screen Replacement: adım 3, 3 resimden 3.
      • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
      • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
      • Safely place the device back on the table by laying the screen face down.
      • There will be some slight overlapping of the back of the case over the screen.
      FixBot'a Sor
      Yorum Ekle
    4. Eee Pad Transformer Prime TF201 Screen Replacement: adım 4, 2 resimden 1. Eee Pad Transformer Prime TF201 Screen Replacement: adım 4, 2 resimden 2.
      • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
      • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
      FixBot'a Sor
      Yorum Ekle
    5. Eee Pad Transformer Prime TF201 Screen Replacement: adım 5, 1 resimden 1.
      • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
      • Repeat the previous process to remove the other ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    6. Eee Pad Transformer Prime TF201 Screen Replacement: adım 6, 1 resimden 1.
      • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
      • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
      • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
      FixBot'a Sor
      Yorum Ekle
    1. Eee Pad Transformer Prime TF201 Screen Replacement, Screen: adım 7, 2 resimden 1. Eee Pad Transformer Prime TF201 Screen Replacement, Screen: adım 7, 2 resimden 2.
      • Remove the six FH-00 2.2mm screws using the Phillips #00 screwdriver.
      • Start heating up the iOpeners now.
      FixBot'a Sor
      Yorum Ekle
    2. Eee Pad Transformer Prime TF201 Screen Replacement: adım 8, 2 resimden 1. Eee Pad Transformer Prime TF201 Screen Replacement: adım 8, 2 resimden 2.
      • Place the iOpeners on the edges of the tablet and let sit for 2-5 minutes
      • Remove the iOpeners and repeat on the other side of the tablet
      FixBot'a Sor
      Yorum Ekle
    3. Eee Pad Transformer Prime TF201 Screen Replacement: adım 9, 2 resimden 1. Eee Pad Transformer Prime TF201 Screen Replacement: adım 9, 2 resimden 2.
      • Slowly pry open the tablet using the plastic opening tool.
      • Place small suction cup on the screen and pull apart slowly to separate screen
      • Be careful not to jerk the screen apart, as this may cause unnecessary damage to the screen or the LCD.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, apply glue to the screen and press it to the LCD, then follow these instructions in reverse order.
David Garcia
322 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-1, Livingston Fall 2016 Cal Poly, Team 10-1, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G1
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 2,086
