Ana içeriğe geç
Eightarc Fusion Logic Board Replacement
Neye ihtiyacın var
  1. Eightarc Fusion Logic Board Replacement, Logic Board: adım 1, 2 resimden 1. Eightarc Fusion Logic Board Replacement, Logic Board: adım 1, 2 resimden 2.
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
  2. Eightarc Fusion Logic Board Replacement: adım 2, 1 resimden 1.
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
  3. Eightarc Fusion Logic Board Replacement: adım 3, 3 resimden 1. Eightarc Fusion Logic Board Replacement: adım 3, 3 resimden 2. Eightarc Fusion Logic Board Replacement: adım 3, 3 resimden 3.
    • Make sure not to flex the logic board when removing ribbon cables.
    • Individually remove the seven cable connectors plugged into the logic board by grasping each white plug and gently pulling upwards.
  4. Eightarc Fusion Logic Board Replacement: adım 4, 1 resimden 1.
    • Use a Phillips Head #1 screwdriver to remove the two 7.15mm washer head screws from logic board.
  5. Eightarc Fusion Logic Board Replacement: adım 5, 1 resimden 1.
    • Gently lift off logic board up to remove from the device.
Sonuç
Chandler Stalford
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G35
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 422
