Ana içeriğe geç
Electric Lint Remover Blade Replacement
Neye ihtiyacın var
  1. Electric Lint Remover Blade Replacement, Blade: adım 1, 2 resimden 1. Electric Lint Remover Blade Replacement, Blade: adım 1, 2 resimden 2.
    • Remove the lint container by sliding to the right until it clicks off.
    • Remove any lint from the lint container for a clean process.
  2. Electric Lint Remover Blade Replacement: adım 2, 3 resimden 1. Electric Lint Remover Blade Replacement: adım 2, 3 resimden 2. Electric Lint Remover Blade Replacement: adım 2, 3 resimden 3.
    • Rotate the perforated cap counterclockwise until it can be removed.
  3. Electric Lint Remover Blade Replacement: adım 3, 2 resimden 1. Electric Lint Remover Blade Replacement: adım 3, 2 resimden 2.
    • Use your flathead screwdriver to get in between the device and the blades.
    • Push the plastic blade holder outward from the device until it pops off.
  4. Electric Lint Remover Blade Replacement: adım 4, 2 resimden 1. Electric Lint Remover Blade Replacement: adım 4, 2 resimden 2.
    • Lift the wire out of the defective blade's hole, using the flathead screwdriver.
  5. Electric Lint Remover Blade Replacement: adım 5, 3 resimden 1. Electric Lint Remover Blade Replacement: adım 5, 3 resimden 2. Electric Lint Remover Blade Replacement: adım 5, 3 resimden 3.
    • Insert the replacement blade into the empty slot.
    • Caution: pinching the replacement blade from surface may result in injury.
  6. Electric Lint Remover Blade Replacement: adım 6, 2 resimden 1. Electric Lint Remover Blade Replacement: adım 6, 2 resimden 2.
    • Flip the cap onto its backside and firmly hold down the side with the loose blade.
    • Pull back the wire using your fingers, and insert wire back into the blade hole.
  7. Electric Lint Remover Blade Replacement: adım 7, 3 resimden 1. Electric Lint Remover Blade Replacement: adım 7, 3 resimden 2. Electric Lint Remover Blade Replacement: adım 7, 3 resimden 3.
    • Insert the plastic blade holder back on the shaft of the device, by aligning the hexagonal hole on the cap with the shaft.
    • Press down gently on the plastic blade cap.
    • Caution: Make sure to press on the cap and not on the blades, otherwise action may cause injury.
  8. Electric Lint Remover Blade Replacement: adım 8, 2 resimden 1. Electric Lint Remover Blade Replacement: adım 8, 2 resimden 2.
    • Place perforated cap on top of the blade cap and turn clockwise until tight.
  9. Electric Lint Remover Blade Replacement: adım 9, 2 resimden 1. Electric Lint Remover Blade Replacement: adım 9, 2 resimden 2.
    • Slide the lint container to the left and press until it clicks into place.
Sonuç
We hope this guide helped you. Happy Fixing!
Chris Koenig
169 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 240
