Ana içeriğe geç
Electric Stove Burners and Drip Pans Replacement
Neye ihtiyacın var
  1. Electric Stove Burners and Drip Pans Replacement, Burners and Drip Pans: adım 1, 1 resimden 1.
    • Unplug the stove or turn off the breaker, if your stove does not allow you to unplug it.
  2. Electric Stove Burners and Drip Pans Replacement: adım 2, 3 resimden 1. Electric Stove Burners and Drip Pans Replacement: adım 2, 3 resimden 2. Electric Stove Burners and Drip Pans Replacement: adım 2, 3 resimden 3.
    • Slide the burners out of the receptacle block.
    • The prongs attached to the burner in the second image fit the slots in the receptacle block in the third image.
  3. Electric Stove Burners and Drip Pans Replacement: adım 3, 1 resimden 1.
    • Lift the drip pan out of the stove.
  4. Electric Stove Burners and Drip Pans Replacement: adım 4, 2 resimden 1. Electric Stove Burners and Drip Pans Replacement: adım 4, 2 resimden 2.
    • Wipe the surface underneath the drip pan to clean it and ensure there are no food remnants
  5. Electric Stove Burners and Drip Pans Replacement: adım 5, 2 resimden 1. Electric Stove Burners and Drip Pans Replacement: adım 5, 2 resimden 2.
    • If all the wires look satisfactory, add the new drip pan.
    • Ensure you have the burner with the open ring so the prongs reach the receptacle block.
  6. Electric Stove Burners and Drip Pans Replacement: adım 6, 1 resimden 1.
    • Slide new burner through the receptacle.
    • Reassemble stove after.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 76
Her zaman: 4,755
