Ana içeriğe geç
Electric Wheelchair Battery Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: adım 1, 3 resimden 1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: adım 1, 3 resimden 2. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: adım 1, 3 resimden 3.
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: adım 2, 2 resimden 1. Electric Wheelchair Battery Replacement: adım 2, 2 resimden 2.
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: adım 3, 2 resimden 1. Electric Wheelchair Battery Replacement: adım 3, 2 resimden 2.
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: adım 4, 2 resimden 1. Electric Wheelchair Battery Replacement: adım 4, 2 resimden 2.
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: adım 5, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 5, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 5, 3 resimden 3.
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: adım 6, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 6, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 6, 3 resimden 3.
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: adım 7, 1 resimden 1.
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: adım 8, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 8, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 8, 3 resimden 3.
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: adım 9, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 9, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 9, 3 resimden 3.
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Paige Efting
159 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 76
Her zaman: 7,414
