Ana içeriğe geç
Electric Wheelchair Battery Replacement
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: adım 1, 3 resimden 1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: adım 1, 3 resimden 2. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: adım 1, 3 resimden 3.
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: adım 2, 2 resimden 1. Electric Wheelchair Battery Replacement: adım 2, 2 resimden 2.
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: adım 3, 2 resimden 1. Electric Wheelchair Battery Replacement: adım 3, 2 resimden 2.
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: adım 4, 2 resimden 1. Electric Wheelchair Battery Replacement: adım 4, 2 resimden 2.
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: adım 5, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 5, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 5, 3 resimden 3.
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: adım 6, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 6, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 6, 3 resimden 3.
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: adım 7, 1 resimden 1.
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: adım 8, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 8, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 8, 3 resimden 3.
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: adım 9, 3 resimden 1. Electric Wheelchair Battery Replacement: adım 9, 3 resimden 2. Electric Wheelchair Battery Replacement: adım 9, 3 resimden 3.
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Paige Efting
159 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 6,792
