Giriş
1. adıma git ↓Common reasons to replace an outlet are for cosmetic and functional purposes. Cosmetic reasons include scratches, cracks, chips, etc. Functional reasons to replace an outlet would include: an outlet is not providing power, an outlet is not holding plugs tightly, and an outlet does not have optional features such as USB ports. This guide shows how to replace a standard residential wall outlet.
Neye ihtiyacın var
Parçalar
Aletler
Turn off the power to the outlets by switching off all breakers that are labelled "receptacle."
Alternatively, you can switch off all breakers.
Use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
Using a pair of wire strippers, place the wire into each groove, closing the wire strippers around the wire to find the size that barely does not fit around the wires.
In the United States, residential wires are typically 12 gauge or 14 gauge, denoted by 12 and 14 on the wire strippers.
7 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
pictures tell the story in the right manner, easy to do.
Thanks from Aria electical
This is a great step by step guide. I wish I had this a couple of years ago. I knocked myself off a ladder because I thought the power was off... didn't test it... and got super lucky. Don't be like me... spend the money on a voltage tester to make sure it isn't live.
if you are in the fullerton ca area and we can help... check us out at http://fullertonElectricpros.com
Just a friendly tip... On Step 17 you could mention using 2 UniShims® as an option for both receptical screws to make the outlet, set more flush with the outlet cover. I found out about the product while tring to find a better and simpler way to make some of my outlets in my apartment look more flush and professional. Instead of using the plastic outlet shims you get and any hardware store and they work great. You should check them out on the UniShim® website.
