Giriş
A common issue with electronic devices is a severed or damaged wire. Whether a dog chews through a wire, a child playing with scissors cuts a wire, or a large appliance slices through a wire, many have encountered this problem. This guide teaches how to remove a damaged plug and replace it with a new plug. The wiring in the lamp plug must be done correctly in order for the lamp to turn on after the repair is finished. This guide shows how to properly locate the "hot" and "neutral" connections.
Neye ihtiyacın var
Locate the damaged portion of wire.
Cut the damaged plug from the lamp cord one inch below the damaged area
Thread the cord so the plug will completely close.
Tighten the exterior screw to close the plug.
Where can I purchase a new plug
You can purchase it at almost every hardware store.
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
18 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Passt - gute Anleitung
A version for 3 prong (North American) would be great
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
what do you do if the replacement plug has no screws to open it?
Buy a plug that can be opened with a screw
How can you tell hot wire from neutral wire?
the neutral wire usually has raised ribbing on its sleeve, and the hot wire has a smooth rubber sleeve. (See Step 2 of the guide)
