Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the 10 mm Phillips #1 screw from the battery cover.
Remove the battery cover.
Slowly and carefully move one side away from another without detaching anything on the device.
Unplug the projector's connector from the circuit board.
Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
Slide the tool along the crease to separate.
Separate the lens and the gear by unscrewing the gear.
