Ana içeriğe geç
Electrohome EAAC475 Speaker Replacement
Neye ihtiyacın var
  1. Electrohome EAAC475 Speaker Replacement, Battery: adım 1, 2 resimden 1. Electrohome EAAC475 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Speaker Replacement, Buttons: adım 3, 2 resimden 1. Electrohome EAAC475 Speaker Replacement, Buttons: adım 3, 2 resimden 2.
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Speaker Replacement: adım 4, 3 resimden 1. Electrohome EAAC475 Speaker Replacement: adım 4, 3 resimden 2. Electrohome EAAC475 Speaker Replacement: adım 4, 3 resimden 3.
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Speaker Replacement: adım 5, 2 resimden 1. Electrohome EAAC475 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Speaker Replacement, Speaker: adım 6, 2 resimden 1. Electrohome EAAC475 Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Carefully and slowly detach one side from another.
    • Make sure the opposite sides are not separated completely.
    • Locate the speaker the inside of the back piece of the device
  7. Electrohome EAAC475 Speaker Replacement: adım 7, 1 resimden 1.
    • Use the flat side of the spudger to remove the glue around the speaker.
    • This glue will need replacing when putting back the speaker.
  8. Electrohome EAAC475 Speaker Replacement: adım 8, 1 resimden 1.
    • After removing all the glue around the speaker, slowly take out the speaker.
    • Be careful not to break anything surrounding the speaker while using the spudger since it is sharp.
  9. Electrohome EAAC475 Speaker Replacement: adım 9, 1 resimden 1.
    • Detach the wires on the speaker and replace them with new ones.
Sonuç
Ruolin Cai
273 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 413
