Giriş
Speaker is a key component for the radio and the alarm in your electrohome EAAC475. This guide will help you to learn how to replace it, should it fail to function.
Neye ihtiyacın var
Remove the 10 mm Phillips #1 screw from the battery cover.
Remove the battery cover.
Remove the two 10 mm Phillips #1 screws from the bottom of the device.
Remove two 10 mm Phillips #1 screws from the back side of the device.
Carefully and slowly detach one side from another.
Locate the speaker the inside of the back piece of the device
