Ana içeriğe geç
Electrohome EAAC475 USB Port Replacement
Neye ihtiyacın var
  1. Electrohome EAAC475 USB Port Replacement, Battery: adım 1, 2 resimden 1. Electrohome EAAC475 USB Port Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 USB Port Replacement: adım 2, 1 resimden 1.
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 USB Port Replacement, Buttons: adım 3, 2 resimden 1. Electrohome EAAC475 USB Port Replacement, Buttons: adım 3, 2 resimden 2.
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 USB Port Replacement: adım 4, 3 resimden 1. Electrohome EAAC475 USB Port Replacement: adım 4, 3 resimden 2. Electrohome EAAC475 USB Port Replacement: adım 4, 3 resimden 3.
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 USB Port Replacement: adım 5, 2 resimden 1. Electrohome EAAC475 USB Port Replacement: adım 5, 2 resimden 2.
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 USB Port Replacement, USB Port: adım 6, 1 resimden 1.
    • Locate the screw holding the USB circuit board in place.
    • Take a Philips head screwdriver and remove the 10 mm screw.
  7. Electrohome EAAC475 USB Port Replacement: adım 7, 1 resimden 1.
    • Upon removing the screw, the circuit board should slide right out to look like this.
    • The USB port is to the right in this picture.
  8. Electrohome EAAC475 USB Port Replacement: adım 8, 1 resimden 1.
    • Find the pins of the USB port that are soldered into the circuit board.
    • Compare the new port with the old port to be sure which pins to work with.
    • Take the soldering gun and heat up the pins one at a time.
    • If you are not familiar with soldering, consult a more skilled individual or at least a how-to guide.
    • Use solder wick with each pin to remove the solder.
    • Remove the USB port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sterling Fulk
264 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 261
