Ana içeriğe geç
Element GC-1020 Display Replacement
Neye ihtiyacın var
  1. Element GC-1020 Display Replacement, Back Cover Replacement Guide: adım 1, 1 resimden 1.
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
    FixBot'a Sor
  2. Element GC-1020 Display Replacement: adım 2, 1 resimden 1.
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
    FixBot'a Sor
  3. Element GC-1020 Display Replacement, Display: adım 3, 1 resimden 1.
    • Unscrew the visible Philips head screws (size: 3.968 mm) on the motherboard located on the top of left and right sides. Use a PH #0 sized screw driver head for removal.
    FixBot'a Sor
  4. Element GC-1020 Display Replacement: adım 4, 2 resimden 1. Element GC-1020 Display Replacement: adım 4, 2 resimden 2.
    • Carefully bend the plastic frame to remove the motherboard.
    • Upon doing this make sure your power button on the bottom left side stays attached to the outer frame because it will loosen as the motherboard is moved upwards.
    FixBot'a Sor
  5. Element GC-1020 Display Replacement: adım 5, 1 resimden 1.
    • The display is attached to a dark yellow, flimsy, plastic material. This material is then attached to the motherboard. Tear off the plastic, successfully detaching the motherboard and display from each other.
    FixBot'a Sor
  6. Element GC-1020 Display Replacement: adım 6, 3 resimden 1. Element GC-1020 Display Replacement: adım 6, 3 resimden 2. Element GC-1020 Display Replacement: adım 6, 3 resimden 3.
    • Once the display is by itself, separate from the rest of the device, you are ready to put in your new display.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lashaun Noel
591 İtibar
5 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
but can i ask do you know how to reboot the software ?
i mean we try to put in our music or video or image inside. can it be done
Nisha Najihah - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 56
Her zaman: 612
