Ana içeriğe geç
Element GC-1020 Screen Replacement
Neye ihtiyacın var
  1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: adım 1, 1 resimden 1.
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Element GC-1020 Screen  Replacement: adım 2, 1 resimden 1.
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
    FixBot'a Sor
    Yorum Ekle
  3. Element GC-1020 Screen  Replacement, Screen: adım 3, 1 resimden 1.
    • Unscrew the bottom of left and right sides of the motherboard.
    • Notice these screws are slightly larger than the ones on the outside of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Element GC-1020 Screen  Replacement: adım 4, 2 resimden 1. Element GC-1020 Screen  Replacement: adım 4, 2 resimden 2.
    • Carefully bend the plastic frame to remove the motherboard.
    • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
    FixBot'a Sor
    Yorum Ekle
  5. Element GC-1020 Screen  Replacement: adım 5, 3 resimden 1. Element GC-1020 Screen  Replacement: adım 5, 3 resimden 2. Element GC-1020 Screen  Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
    • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
    • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
    FixBot'a Sor
    Yorum Ekle
  6. Element GC-1020 Screen  Replacement: adım 6, 3 resimden 1. Element GC-1020 Screen  Replacement: adım 6, 3 resimden 2. Element GC-1020 Screen  Replacement: adım 6, 3 resimden 3.
    • Carefully pry apart the screen from the frame of the device.
    • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
    • If done correctly, your detached screen will look like this.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lashaun Noel
591 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 44
Her zaman: 583
