Ana içeriğe geç
Ematic FunTab 3 Camera Replacement
Neye ihtiyacın var
  1. Ematic FunTab 3 Camera Replacement, Back Panel: adım 1, 3 resimden 1. Ematic FunTab 3 Camera Replacement, Back Panel: adım 1, 3 resimden 2. Ematic FunTab 3 Camera Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Camera Replacement: adım 2, 1 resimden 1.
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Camera Replacement, Camera: adım 3, 2 resimden 1. Ematic FunTab 3 Camera Replacement, Camera: adım 3, 2 resimden 2.
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Camera Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to flip up the black retaining tab.
  5. Ematic FunTab 3 Camera Replacement: adım 5, 2 resimden 1. Ematic FunTab 3 Camera Replacement: adım 5, 2 resimden 2.
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
Sonuç
Amanda Davis
581 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G5
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 152
