Ana içeriğe geç
Ematic FunTab 3 Touch Screen Replacement
Neye ihtiyacın var
  1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: adım 1, 3 resimden 1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: adım 1, 3 resimden 2. Ematic FunTab 3 Touch Screen Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic FunTab 3 Touch Screen Replacement: adım 2, 1 resimden 1.
    • Pull the back panel away from the screen.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic FunTab 3 Touch Screen Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the black tape to reveal the screen connector.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic FunTab 3 Touch Screen Replacement: adım 4, 2 resimden 1. Ematic FunTab 3 Touch Screen Replacement: adım 4, 2 resimden 2.
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic FunTab 3 Touch Screen Replacement: adım 5, 2 resimden 1. Ematic FunTab 3 Touch Screen Replacement: adım 5, 2 resimden 2.
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
    FixBot'a Sor
    Yorum Ekle
  6. Ematic FunTab 3 Touch Screen Replacement: adım 6, 1 resimden 1.
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    FixBot'a Sor
    Yorum Ekle
  7. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: adım 7, 2 resimden 1. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: adım 7, 2 resimden 2.
    • Insert the hook side of the opening tool between the case and display.
    • Press down on the tool until the screen is clear of the white retaining tabs.
    • Use the plastic opening tool to gently pry up the screen.
    • This is best done on the corner closest to the wire ribbon.
    • Continue prying around the screen until the screen pops out.
    FixBot'a Sor
    Yorum Ekle
  8. Ematic FunTab 3 Touch Screen Replacement: adım 8, 1 resimden 1.
    • After the screen has come lose, remove it from the device.
    • When reassembling, make sure the screen locks in place, this may require extra pressure
    FixBot'a Sor
    Yorum Ekle
Sonuç
Amanda Davis
581 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G5
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Where can I get a new display for my emoticons funtab 3?
DanTheMan RBLX - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,236
