Ana içeriğe geç
Ematic Genesis 2 Audio Jack Repair
Neye ihtiyacın var
  1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: adım 1, 2 resimden 1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: adım 1, 2 resimden 2.
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Audio Jack Repair: adım 2, 3 resimden 1. Ematic Genesis 2 Audio Jack Repair: adım 2, 3 resimden 2. Ematic Genesis 2 Audio Jack Repair: adım 2, 3 resimden 3.
    • Remove all four screws surrounding the battery with the screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Audio Jack Repair: adım 3, 1 resimden 1.
    • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
    • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 162
