Ana içeriğe geç
Ematic Genesis 2 Charging Port Replacement
Neye ihtiyacın var
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: adım 1, 2 resimden 1. Ematic Genesis 2 Charging Port Replacement, Charging Port: adım 1, 2 resimden 2.
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: adım 2, 3 resimden 1. Ematic Genesis 2 Charging Port Replacement: adım 2, 3 resimden 2. Ematic Genesis 2 Charging Port Replacement: adım 2, 3 resimden 3.
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: adım 3, 2 resimden 1. Ematic Genesis 2 Charging Port Replacement: adım 3, 2 resimden 2.
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: adım 4, 2 resimden 1. Ematic Genesis 2 Charging Port Replacement: adım 4, 2 resimden 2.
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: adım 5, 2 resimden 1. Ematic Genesis 2 Charging Port Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: adım 6, 1 resimden 1.
    • Solder replacement port into place.
    • Make sure all connections match original.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 560
