Ana içeriğe geç
Ematic Genesis 2 Screen Replacement
Neye ihtiyacın var
  1. Ematic Genesis 2 Screen Replacement, Screen: adım 1, 2 resimden 1. Ematic Genesis 2 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: adım 2, 3 resimden 1. Ematic Genesis 2 Screen Replacement: adım 2, 3 resimden 2. Ematic Genesis 2 Screen Replacement: adım 2, 3 resimden 3.
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: adım 3, 2 resimden 1. Ematic Genesis 2 Screen Replacement: adım 3, 2 resimden 2.
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: adım 4, 1 resimden 1.
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 451
