Ana içeriğe geç
Ematic Genesis Camera Replacement
Neye ihtiyacın var
  1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: adım 1, 3 resimden 1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: adım 1, 3 resimden 2. Ematic Genesis Camera Replacement, Ematic Genesis Casing: adım 1, 3 resimden 3.
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic Genesis Camera Replacement: adım 2, 3 resimden 1. Ematic Genesis Camera Replacement: adım 2, 3 resimden 2. Ematic Genesis Camera Replacement: adım 2, 3 resimden 3.
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic Genesis Camera Replacement: adım 3, 1 resimden 1.
    • Remove back plate from screen plate and lay both down flat next to each other.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic Genesis Camera Replacement, Camera: adım 4, 2 resimden 1. Ematic Genesis Camera Replacement, Camera: adım 4, 2 resimden 2.
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic Genesis Camera Replacement: adım 5, 2 resimden 1. Ematic Genesis Camera Replacement: adım 5, 2 resimden 2.
    • Lift up the black lever of the connector that holds the camera ribbon in place.
    FixBot'a Sor
    Yorum Ekle
  6. Ematic Genesis Camera Replacement: adım 6, 2 resimden 1. Ematic Genesis Camera Replacement: adım 6, 2 resimden 2.
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Justin Rohrman
745 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 43
Her zaman: 442
